The 1992 F-350 single wheel Dana60 I ordered came in today. I hoped it would have the tie rod assembly etc. but it isnt there. Can I use the TTB steering linkage ? Can I use the TTB track bar? What about the rubber brake lines? Is the front driveshaft the same? How about the front leaf springs and hangers?
I also noticed that the swaybar was bent on the Dana 60 so can I use the TTB unit?
Will the 60 be taller and create a little lift or will things stay the same?
Are there any other things I am going to run into during the swap out?
The yard has another 1993? F350 front D-60 for sale... $400.00 minus one side axle shaft brakes and spindle. 1-800-545-8885 from a Dually with 4.10-1 gear ratio.
It is located near the south west corner of Wisconsin or the north west corner of Illinois so if you live close you may save on shipping.
Thanks,
Eric
Thanks,
Eric
