Stuck copper washer
Sycostang67
Scooty Puff Junior
Kuna, ID
I had to scrape around the top to break up the crud that was holding mine in, I had a 4 piece pick set that came in real handy
HammerDown
Glenolden Pa
Simple...spray a shot of BP-Blaster, wait a few moments, insert a philips screw driver and give it a little tap. Now you'll need something to pick it out with. I use a dental pick.
f-two-fiddy
Duluth, Mn.
Also, when they get sooted up like that, it's a sure indicator that the copper gasket was leaking compression past the injector. Make sure You clean the seat, or it'll happen again. NOT good for the injector!
Hyde
N GO SEEK
Idaho
This leads me to believe you're pullin injectors, those ones I sent ya gonna do any good?
dyoung14
Is getting worn out
spencer,tn
i have them setting here, but none of thats doing me any good now check my newest thread:puke:
Hyde
N GO SEEK
Idaho
Thats sucks man, im havin fuel system issues as well
Sycostang67
Scooty Puff Junior
Kuna, ID
What the heck...are you trying to corner the idaho market on used injectors? Does that mean you wont be needing mine anymore? I was gonna get that shipping quote for you tomorrow now that I have a truck again.
dyoung14
Is getting worn out
spencer,tn
what im trying to do is build a tester, then build and pop test used injectors to sell used injectors to people who cant afford new sets, but right now i cant afford to do nothing but change my engine so i cant get them from you now
Big Bear
