Tim the 2lman
I bought this '94.5 no run and thought I'd simply wave the magical mechanical wand and have it runnning. Well no such luck. After a month and a half, It still isn't runnning and doesn't act like it wants to. I'm not getting sufficient oil pressure while cranking for the PCM to tell the IDM to come online. Getting 476psi and need min. of 500psi. Installed a good used HPOP from an '02 PSD did the mods to the front cover and installed '02 reservoir. Original pump gave me about 425psi. These numbers are with one oil line capped off and the other line terminated into an oil filled 0-4000psi guage. Crank speed is ok but not great. I've seen these things crank slower and still fire up though. I've got fuel pressure but I haven't put a guage on it to measure how much. I've tried unplugging the ICP but it still doesn't fire up. Anyone got ideas?
I am concerned that I may not be getting good voltage to the PCM while it cranks. Any idea what that voltage should be? The wire that attaches to the battery terminal and feeds the starter relay where everything is fed, gets mighty warm when the GP's are cycled on and it's cranking.
I've got to be over looking something very simple.
...The old PCM was so bad that it fell apart when I pulled it out.
