stereo wiring?
zacky6661
the dalles, or
i know this really doesnt revolve around the motor, but i have a 1984 f250 XLT and im putting a new stereo in, and i was wondering if anyone has/knows the color codes in the truck for which speakers which, constant 12v, accessory 12v, etc. ?
WrecklesCustom
First Timer
San Francisco CA
If you have never done a sound system before this is the easiest way to do it. 99% of the time wires do not go bad it is just the system (speakers, headunits etc..) themselves that are the problem.
With this system you plug it right into your factory plug, it also allows for you to run extra speakers as well. (I used this but soldered the wires together)
http://www.crutchfield.com/p_120705001/Ford-Receiver-Wire-Harness.html?tp=2977
J
zacky6661
the dalles, or
the thing is, i didnt have a plug going into the factory radio. the wires just went straight into it, so i had to cut them to get the radio out.
jwalterus
Made in America
Garrison, ND
there should be a plug somewhere in the dash then, might be hidden somewhere and stuck on a bracket, but it'll be there if you just cut the wires off of the deck
if not, take a test light or multimeter and check the wires, with ignition on, you should have power to one or two of your wires, if there's power to two, then you have a constant (will be yellow on a new deck) and a switched (red on new deck), turn the ignition off and check them again, the one that turned off is obviously the switched, if you only have a switched power wire, you need to run one to the battery
the one with the plug is the antenna
the rest will be a ground and the speaker wires
to find the ground, repeat the test above with a known power wire, and touch the others one at a time to find the ground using a test light or multimeter
after you know the ground, put power to one of the remaining wires, then touch them one at a time to a ground, when you hear a noise from a speaker, those two are a speaker pair
but as I said, you should have the factory plug somewhere in your dash still, just follow the radio wires to it
zacky6661
the dalles, or
no factory plug, just looked and dug around, all i have are 8 wires, ive tested them all with a light and i only come up with 1 wire thats wired on accessory. i dont have any constants, and i dont know which wires are for my speakers.
input?
Hyde
N GO SEEK
Idaho
Left Front (+) Green
Left Front (-) Black/White
Right Front (+) White/Red
Right Front (-) Black/White
Edit: All on are that link
zacky6661
the dalles, or
i dont have those colors, the ones that went into the factory radio are: pink/blue, black, pink/light green, orange/green, and white/green. those go in on one side, and the other side has blue/red, pink/green and orange/blue. those are the only wires i have. and only 1 tests as switched, cant find a constant.
zacky6661
the dalles, or
give me an idea where in the dash to look for it cause i cant find anything besides the wires that went to the factory radio and wires that go to my heater, a/c , fuel switch etc.
Hyde
N GO SEEK
Idaho
Follow the old stereo wires as far as you can, cant be too far
82F100SWB
Sioux Lookout, Ontario,CA
Depending on which stereo you had, there may not be a plug, and if if it's an old 2 post analog radio, there won't have been a constant power source either. I usually tap into the cigarette lighter power feed for that.
From the sounds it, the existing stereo is wired with a common ground for the speakers. This is not something you will want to keep, so you're best off just to run new wiring.
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
J
I did the same thing in my 1996 F150. When it blew up, it unplugged and went right into the F250. By far the easiest way to put in an aftermarket deck....just match the colors up and plug it in!
Studebaker62
