JPhauler87
What's a common application you guys are using for the steering pumps with no reservoir? The gear pump that came with my PA bio fuge crapped and is $200 to replace.
i didn't "driect drive" mime. you might want to use some pullies to bring the motor rpms up and load down.Works great, but electric motor is getting got. Ran for about an hour last night and IR temp gun was reading 190* and climbing. Current blend is a little thick and pressure set at 90psi, hoping thinning it out a hair and running at 80psi will keep it sustained at a cooler temp.
I don't remember the motor getting hot at all with the gear pump. Do your guy's motors get hot?
