Heide264
Good Afternoon,
(long story)
As a bit of background, I picked up a 94 F350 4x4 with the turbo'd 7.3L in it. The truck only made turns at higher RPMs, and needed/needs a ton of work. The brakes are terrifying. I have a refurb'd power steering pump in it now, with the extra return nipple. I also picked up a refurb'd gearbox and have that bolted up (but not attached to the ball joint, yet - figure that'll help to prime it). I still have to run my lines. I am planning on doing a hydroboost conversion while my truck is still weighing my parking pad down. I think as of now I'll be getting a chevy unit and shortening the push rod.
So I have the high pressure lines from the pump to the hydro and the hydro to the gearbox in my garage. I believe they should both fit - with one fitting being questionable as it's a metric vs english mash up.
...As typical, I destroyed every flared fitting possible while dismantling everything, even with a set of decent flare wrenches. So I am left with needing the return line from the gearbox to the pump, including 'cooler' loop thing.
I thought after redoing the whole system, I may as well pick up a $30 derale cooler from amazon that I can mount nicely by the radiator somewhere (Amazon Link). It uses 11/32 hose barbs as inlet and outlet.
(short story)
I figure I can skip out on that whole little return line with the cooling loops (which looks like a bleeding nightmare, by the way) by just getting a barbed fitting for the return port on the gearbox, running 3/8" generic tubing from there to the cooler input barb (with some fighting on the 11/32" barb), then 3/8" generic tubing from the cooler output barb to one of the return ports on the pump.
I was thinking about using this straight into the gearbox return port: Fitting Link
My main concerns/questions:
1.) Is there any issue with using brass/copper in a power steering system?
2.) Given the factory line doesn't use a flared fitting to attach to the pump, I am assuming that the return is low enough pressure that some well placed Oetinker clamps will seal all return connections up for a looong time.
3.) I'm an engineer, and I make things overly difficult. I also am NOT a diesel mechanic. My only hydraulic experience has been with the brakes and fuel rails/lines in my Subaru, so any advice, reality checks, or concerns on the matter would be appreciated.
Thanks guys! I've been reading for a while on the boards and I appreciate all the knowledge!
(long story)
(short story)
