'94IDITurbo7.3
HAMMER DOWN!
Today when i went to crank my truck over after school i got nothing. i had to turn the ignition off, then back on and it turned over just fine.
the speed at which the starter cranks the engine over has been just fine.
the bats are good along with bat cables and grounds.
i suspect the ignition switch under the dash, but i have no evidence towards ruling out the ignition lock cylinder, starter relay, or the starter itself.
I do believe the starter was put on by the PO but it is all oily due to the leaky valve cover gaskets which have been fixed since this past spring. So other than the oil the starter "should" be just fine.
I don't know when i will have the time to do any diag work on it. mabey this coming weekend.
what kind of things should i test and look for?
In the meantime what is needed to start the engine from under the hood just in case it won't start from in the cab?
Do i jump the 2 big terminals on the fender mounted starter relay?
What do i have to do to power the IP?
Thanks in advance
Thanks in advance
