Chad241993
Can a Standard Starter/Glow Plug Solenoid be used as an ignition relay for constant duty? It would be my main power supply to run everything.
Uh...I did exactly what he's saying on my '88. Everything but the alternator through the continuous-duty relay.What do you mean by "run everything"? A relay can't be a "power supply". The "power supply to run everything" is the combination of the batteries and the alternator. A relay is simply a switch. There are plenty of circuits that you do NOT want to switch off, the two most obvious being the hazards and the brake lights.
A simple battery cut-off switch (it could still be wired exclusive of the alternator) would be simpler and more reliable. And one less point of failure.
