im having a difficult time finding a new or used OE clutch fork for my 83 F-250 w/ T-19. Do any of y’all have a good used one? Tried sourcing one through the dealer route with no luck, reason I’m looking for one is that are which makes contact with the pivot ball is gouged out badly. I was able to source a pivot ball though.
The after market one I bought is slightly different and not sure if it would pose any problems or not. Apparently our 6.9 with the T19 4 speed took the same clutch fork as the trucks with the 460 gasser.
Problem with the aftermarket clutch fork is the end which engages the throw out bearing is radiused slightly different. Shop said they could grind it down better but a good used OE one would be best.
The pics show my original clutch fork with part # E3TA-7515 DC, and a screenshot of the aftermarket unit, an ATP part # ZA-126. Aftermarket one has my Ford clutch fork listed in its applications chart but it’s not an exact match.
The transmission shop with my truck has strongly encouraged me to source an original clutch fork versus using an aftermarket one. Thanks
