So I decided to pull the oil burning engine. Overhaul questions
Brad S.
NW IA
After having the heads done and the turbo gone through, the engine is really going through a lot of oil, still.
Pretty sure I'm gonna have the block sleeved, new cam bearings, check the crank, all the normal block checking stuff.
Would really like to reuse the pistons, but can the piston skirts be scuffed and still be useable? (Haven't got it tore apart yet, dont know if the are scuffed)
Like to use the gapless rings on the second groove. Are there some rings that would be better with wmo or that put up with extra particles?(for the top & oil rings)
Like to use the oil pump again, doing some reading in the past and it sounds like this is possible??? What makes the oil pump bad???
My heads will be sitting during this time which could be most of the winter. Whats the best way to protect the chambers on the head from rust??? And do they need to stand on end to keep from warping??
I will say that pulling the front clip off the pickup makes a huge difference on working on the engine, if your thinking of pulling a motor consider it.
Feel free to give your experiences, thanks.
chris142
SoCal
As far as reusing parts. Ring lands on pistons wear and have a max allowable clearance. Oil pumps get grooves in the gears and pump body and are normally replaced during a rebuild. Remember that the oil pump is before the filter so it gets a constant supply of unfiltered oil.
How much oil was it using? Mines around 600-800 miles per qt. Imo that's more than id like but ill wait till it gets worse before I fix it.
junk
Paullina, IA
Yeah, pull it apart and start measuring things up. Then you will know what you can reuse. Since you had the heads done sounds like you have a machine shop you trust. I've been using Arnolds motor in Sheldon for my engine work. He's quick and pretty straight forward.
1qt to 100 miles. hell I was going through 1 gallon to 100 miles. I haven't torn my old engine down yet to check it out.
Brad S.
NW IA
:eek::eek:
Just when think you have it bad....
Not that I feel better about mine but wow.
No holes in any pistons????
junk
Paullina, IA
I drove it to Chicago and back like that. I never thought it smoked but it must have. It ran when pulled so I've been hesitant to tear it apart any further.
typ4
Newberg,OR
Take the cover off the oil pump, I guarantee the used IH piece is better than any new aftermarket . The melling I have in mine is a pos and the rep actaully told me"we cant inspect every one" I about had a fit. So IF I ever have to pull my engine it will get the "old" pump back in.
And as for the pistons, look carefully and measure, I reused mine first go around and then one collapsed, been doing engines 30+ years and never had this happen, but it did get hot which im sure was a contributing factor, if the tops of the pistons are "washed" that means oil has been coming past the rings or lands.
And I will never pull another one with the clip on, so fast to do without.
wildman7798
Great Pacific NW
I know that Melling has done them and offered them for racing applications and I have heard of machinists doing this as well, ask your machinist if it's possible to blueprint your oil pump if you buy a new one. In most cases it is deburring, possibly milling and checking all the gear and plate clearances. You never know until you ask. The IDI's can't be the only diesel engines getting bottom of the barrel oil pumps. It is the old supply and demand thing but a good machinist/engine man can do some amazing things.
fsmyth
conroe, tx
Scuffs will polish out. Mike the skirts after, make sure the clearances are good. (probably will be w/ new sleeves).
Filter out your extra particles, before using WMO. I'd be more worried about injectors and IP than rings.
If you had good oil pressure before, the pump is still good. Use it.
Spray 'em down with light oil and wrap 'em up in poly. Don't need to stand on end, but they take up less room thataway :)
Are you thinking of sleeving all eight cyl? Or what are you contemplating?
Why are you wanting to sleeve the engine? If it is to true up bores and remove taper and such why not forgo sleeve and do a slight bore 0.010 or 0.020 etc? I'm thinking cost here
So you want to pay to bore and sleeve and then hone cylinders out to use used pistons? Am I correct that this is a cost savings measure? If so it will cost you more in the end IMHO for not doing the engine correctly.
There are gapless check with Total Seal on their products, this may require machining of piston or not and it's not something you want to waste $$$$ on on used pistons of unknown condition. However that being said IIRC there is also a standard with ring that's gapless too. I just don't recall!
As for a better ring for abrasive WMO; filter the WMO better, much better and then go with a cast ductile iron ring, knowing they are good solid rings! Plasma moly will just wear away quicker...IMHO
Yes you can use the oil pump again. I would suggest getting a factory manual FORD manual and then get the specs and blue print the oil pump yourself. It is not that difficult. You will need to inspect it for wear and so forth but you can blue print it at home with nothing more than good quality flat surface thick thick glass and emery and some oil. You would be removing and polishing the parts and making sure that all the clearances are in spec!
Light oil coated and bagged as mentioned also see about a desicant sack you can toss in the bag suck out the air with a vacuum if you can and seal and leave alone!
Yes clip removal is truly the best way to get the engine out bar none..its my preferred method to as seen in my pics LOL
I just don't get the rebuild the heads and now you want to do the bottom end and skimp on new pistons...sorry that makes ZERO sense to me none what so ever.
JM2CW
Al
Sgtbyersfw
