SMF kits
Va_Mike
Southeastern Virginia
I want to put a new clutch in while I have my engine out. I don't know what flywheel the truck currently has, how do I know if it is a single or duel mass? I am looking at the three kits they have on rockauto for the SMF conversion. Has anyone used the kits from there? This engine will probably only be in the truck a couple years so is there any problems with just going with the cheapest kit and then getting a good quality one when I put the rebuilt engine in later?
BlackNoma
Sweeny, TX
I am using a Luk SMF with the M-pact clutch disc and pressure plate. Works perfect.
I went this route instead of the DMF because I didn't want another clutch to worry about going out eventually... and it's cheaper for SMF. lol.
I figured our trucks will never be quiet anyway, so who cares about the extra chatter with the SMF?
hesutton
The Anti-Anderson
Bowling Green, KY
Have never used a kit from RockAuto. Who makes those kits?
I have clutches from South Bend Clutch on both my IDI's. I used their SMF 13 inch kit on the 6.9 crew cab when I did the 460 ZF5 swap. It's worked well.
So you aren't planning on keeping the IDI in the truck for long? How much do you tow with the truck? How heavy? That will make a econo kit vs. quality kit decision easier.
Heath
Va_Mike
The kits available on rock auto:
AMS Automotive 192.79
Perfection Clutch 232.79
Valeo 413.79
I was leaning towards the Perfection Clutch kit because they have a decent reputation.
I have read that The SMF is ******* the transmission and couses gear chatter? why?
If I have a dual mass flywheel and it appears in good shape can I just put a new clutch on it and go?
I will be doing some towing as this will be a business truck (8,000 -10,000)
But I am going to rebuild the engine I am pulling and that will get better parts than this replacement gets.
hesutton
The Anti-Anderson
Bowling Green, KY
Valeo is a quality clutch. No experience with Perfection or AMS.
You will get more rollover noise with the SMF, but I've never read/seen where SMF's are a root cause for trans failure.
If you're gonna haul with the truck, I'd worry about slipping if the clutch quality isn't there. What spec's are given for the Perfection kit?
If your flywheel is good, and you plan on reusing it..... be sure to have it surfaced before putting a new pressure plate and disk on.
Heath
Oldiron
Florissant, CO
2nd on the flywheel resurfacing. I have always done it that way, but friends haven't, and there is a differance
Macrobb
North Idaho
Get the Luk kit. They work great. Minimal rollover noise.
I think I got mine from PartsGeek; they were cheaper than those prices by far.
And, of the last 2 clutch replacements I've done... it's been the flywheel(and it's built in 'torque limiter') each time. Clutch was OK.
YJMike92
NW Arkansas
Valeo is a reputable brand as well as the LUK brand mentioned above. The other brands I have never heard of. They aren't less expensive for no reason (you get what you pay for). Spend the extra money and get quality.
Va_Mike
I hope I can resurface the one that is there. Is there a good write up on how to check if they are still good. I have not driven this truck so I don't know anything about it other than the clutch works for taking it out of gear to roll it around the driveway. If I have to get a SMF kit it will probably be the LUK I found it for $280 I seem to recall. I am ok with throwing cheaper parts at something I can get to easily to replace but the clutch is not one of those.
Danielle
No, it's not finished
Dirty Jersey
I didn't want to start a new thread when this was my same question. What did you end up going with?
AMS is listed as "Heavy Duty". I only use my truck for towing and hauling so want one that is made for it, but I have never heard of AMS and M-pact sounds like our favorite manufacturing country.
Va_Mike
I haven't gotten that far yet. I am currently resealing the donor motor and plan on pulling the engine from my truck in the next week and then I will decide if the flywheel I have is usable. My truck is going to be a work truck and tow vehicle so I want something that will hold up.
chillman88
Central NY
Well, since we're all beating a dead horse here anyway... :p
What's everyone's opinion on drilling the flywheel for the slightly larger PSD clutch? I asked on Facebook and got mixed replies, figured I might as well ask here.
Some guys said the LUK kit slipped for them with big loads, others said it was fine, the replies were all towing with turbos. Regardless of what gets done its not a fun job to do twice.
BrianX128
Pittsburgh
I have the luk kit in my 7.3 and hauled 6 tons behind me on a trailer once and had no issues there or with normal use.
I will say the clutch is super light on my 6.9, but there's something about the throwout bearing on the zf in my 7.3 that didn't have an amazing jump in ease of pressing the pedal. Both are luk kits and both got put in last winter. Just a strange observation..
firehonomichl
Worland Wyoming
I just did the LUK SMF conversion in my 89 and it works great! I got mine from parts geek and I think it was $291 shipped to my door.
Ramtough01
