Small gas engine additives
rreegg
IDI n TDI
Puget Sound
I’ve a couple small gas kicker outboard engines and a generator. I put ethanol free gas in all of them but curious about additives. I use the marine Stabil additive for the outboards but curious if it’s problematic to use this in the generator engine? Not sure the difference between marine (blue bottle) and non-marine (red bottle) Stabil. I just want to be able to use the same fuel cans - with additive- across these engines and curious if it makes any difference. Thanks for any help or if there are other suggestions I’m all ears
reason I’m asking because I don’t have any gas vehicles and can’t use old gas anywhere, just want to make it last longer for the small carb’d engines - they’re all 4 stroke
Cant Write
Placerville CO
I used to use only the marine grade (blue) stabil and I don’t own a boat. Reason, well I can’t remember :rotflmao but I know I had one.
Once I found out it only keep gas good for a year and red is good for 2 years, I switched to red.
Personally, based on what fire departments do, I keep everything dry (run till it quits). Had a push mower sit 7 years and it fired on 4th or 5th pull once it got gas. I can see boat tanks being harder to keep empty.
To make a long post longer. Dads ‘79 only gets run every year or 2 when I am up there. I drive it the entire time I’m in SD. I keep the tank plumb full and red stabil mixed in. take the battery inside dads house. Never had a carb problem on that engine.
klook
Harrison, Tenn.
I have used the red label Staybil and I like Seafoam. I have not had engine problems since I started using it. But I also buy non ethanol gas also. It is not as good as the old leaded gas for long term storage however.
rreegg
IDI n TDI
Puget Sound
Nice I’d consider using seafoam as well, didn’t know red Stabil was good for 2 years. Seems they’re probably all the same for the most part..
