Slip joint up pipe?
OldIron82
Northampton PA
Hey everyone. Getting closer by the day on getting the 6.9 done. While replacing studs today on the turbo up pipe, I noticed what I call the slip joint ( correct me please ) does not appear to be bottomed out but also no evidence of leaks either due to lack of soot. Is this normal, or should I heat it and beat it apart? I'm guessing it's a interference fit so I suppose rusting up helps seal it but I'm concerned that not being bottomed out in the up pipe might come back to bite me. What are your thoughts?
Also, should I sandblast and paint all these parts before header wrap, or itsy header wrap them as is?
Thank you.
Sent from my LG-H810 using Tapatalk
shawn deere
nebraska
Id leave it man. You can beat it apart then itll start leaking. Itll be black if it was thinking of leaking. I actually welded mine cuz it was loose...
Rossroams
South Carolina
I'll second that on leaving it. I beat mine until it came loose and now I have a major exhaust leak. It's definitely not leaking how it is.
pwillis
