Skys rear rsk
Greg5OH
MI
have a 2wd CC. will be going 4wd. Stock 2wd has no lift blocks between springs and axle and would like to keep ot that way. Should I opt for the HD kit whoch gives 5.5" lift vs 4.5?
Anything i can/should do to have correct pinion angle WITHOUT lift blocks?
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
wait a week. I have the 4.5 inch kit on my crawler and a friends truck. I just ordered their 6 inch kit for my f100. will fill you in when I get it.
Greg5OH
MI
great, PM me or reply to thread once its off. thanks.
Greg5OH
MI
Since im 2wd currently, i will be doing an rsk in the fromt as well. i want the rear higher than the front anyway. Now i just hope i can do that with just the shims but im not ruling out putting a 1-2" block underneath to get some rake going.
Dieselcrawler
Staff member
Quakertown Pa
My buddies truck we did a solid axle swap with a addaleaf in the front. Installed flip kit in rear with no blocks. Truck ditties level. Pinion pointed up a little. Installing a factory bronco block would fix his pinion and give it some rake, but it is farm truck, he wasn't worried about pinion. Now the shackle flip in the rear will move your axle forward about an inch. With a regular bed this will put the wheels not center in wheel arches. He has a flatbed on it so you don't notice it.
Greg5OH
MI
They say if you add the taper blocks it moves the wheel back to stock location? Definitly want axle in stock location. Im assuming with teh HD kit it would also move the axle forward 1"?
Now my concern is
1) how to keep soome rake
2) keep the axle in stock location.
Let me get this straight.
This is all rear spring hardware I'm speaking about here BTW
If I take A forward spring mount mount that on the rear and do a shackle reversal, on my white truck it will bump the diff forward about an inch? And as well as that, it will have a slight pointing upward of pinion correct?
Thus would you not need a new rear drive shaft for the length to be correct?
I'm wanting to do a shackle flip with an extra set of forward stock spring mounts on my truck mounted to the rear section to support the shackle and make the flip kit.
Also would a small plate 1/4" thick along the outside of frame on both L and R frame rails, between the spring mount and frame cause; IN YOUR OPINION, a major problem with spring action etc? I'd like to make longer and stronger bumper mounts for the rear of my truck and between spring mount and frame is really only way to do so.
Al
burt
redding,ca
I'm confused. Nobody is really talking about a shackle reversal in the rear are they? It's a shackle reverse in front and a shackle flip in back, right?
Leeland
Oregon
Reversal= front, Flip= rear
burt
redding,ca
That's a relief. In the off chance you missed this, if you are going to the trouble of doing an rsk it is definitely worth it in my opinion to do it with 99+ length superduty springs.
Dieselcrawler
Staff member
Quakertown Pa
ok, after installing the 6 inch kit on my f100, it is pretty simple. I do like how they are made, they look great. front hangers are massive, held on with 8, 1/2 bolts. will get pics tomorrow.
before with kist 4 inch blocks
after with 6 inch flip kit and 1.5 inch blocks.
Greg5OH
MI
massive indeed, looks awesome!!! that truck looks tuff!
like the rake.
Seems your axle is nice and centered?
That is aproximately the hight I would like my truck at. maybe a touch lower. Inch or 1.5" all around.
Dieselcrawler
Staff member
Quakertown Pa
rear axle is centered nicely. also pinion looks decent. wont know till I get my rear shaft made. right now it is a front wheel drive f100....
Also, this truck is high... not sure you want this tall. lol I have 32 inches between ground and bumper on the rear. and that's only with these 33's. hood is at my arm pits, I am 6foot2
bneumann22
Staff online
