Waystro
No Class
Yes it has cruise.Maybe cruise control related? Do you have cruise on that truck? It looks familiar but I can't place it exactly.
Ok I jumped from the starter relay to the battery it cranks over but will not crank by key I should also note that the key is hard to turn past the accessory notch. How hard is it to replace the key switch? I have a switch from my 86 I could throw in or should I just get one from oreilys?Make sure it's in park.
Passenger fender is the starter relay just aft of the battery. Remove the small wire (push on black 90* connector, easy to do), and jumper that terminal to +12 - should turn over. If that works either the park/neutral switch or the key switch is bad/out of adjustment. If it still doesn't check to see if there's +12 on the output of the relay with it jumpered. If so you need a starter. If not a new relay. Simple system.
