its not the 3g that's the kicker, its the fact that its internally regulated, and you can hook it up straight to the battery and clean up your wiring, not to mention one less item to diagnose.
when it comes to serp, most of the issues people have had here comes from the open spring design.
where mis installation is very common due to having to tighten the bolt down with spring dragging on the casting.
and the fact that they are prone to failure.
us avid serp fans switch to the closed spring tensioner, which is actually a completely different drivers side bracket.
we also install the tensioner with the shock.
I have not any issues since I replaced everything and got it on point.
the belt does chirp in the morning when driving it hard, but only till it warms up.
they are more or less problem free.
look at all of the modern cars now a days, you can prolly count on 1 hand which manufacturers still use a v belt, and its usually to drive 1 item.
people say "if you throw a belt, you loose everything...
which is correct. but you know about it immediately.
**** happens. all cars are junk, and they always break.
this is why we are all here in the first place
hay
@Clb how many miles were on your truck when the open spring took a dump?
