rmyers2051
KV8OOA
First off, 96psd, 246k miles,swamps baby's, bully dog chip, straight exhaust, stock intake.
When driving unloaded, not towing, just commuting to and from work truck uses about 5 quarts of oil between changes, and I suspect that the majority of that is a leak. Normally drive about 22 miles from start to stop, rural setting 4 lane, 55mph speed limit. fuel mileage is just as it was when truck was stock with 80k miles, around 22/25 depending on how much I run interstate.
A few weeks ago I towed my off roader on 16 ft trailer to play in the woods for the weekend, when I got on the interstate I hammered on it to blend into traffic, it pulled up to 2800 or so and started smothering down like I had let off of it. I backed out got the next gear and it began pulling again. Off and on like this for the 80 mile trip. Fellow following along with me said my truck was blowing a lot of blue smoke, but since I havea 99 tailpipe on it that does not extend out to the edge of the truck he couldn't tell where it was coming from. Get to where we are going and I didn't think any more about it, rode in the woods for a few hours(Bronco) and when I came back and loaded up I checked the oil in my psd. It was 2 gallons low. I filled it back up with the normal elixer of Shell Rotella T, and started home. It did the same thing with pulling down and missing. I determined that anything over 2krpms, and or 15psi boost would aggravate this situation. It used 1 gallon of oil for the 80 miles back.
On M onday I called my local guru and he suggested the obvious-bring it in.
Well, they decided that I needed a turbo rebuild, a pedistal reseal and a ebpv seal kit. Blowby was determined to be very minimal(unknown as to how this test was performed) $680.00 and ONE WEEK later I get the truck back, it actually runs better somewhat. Seems that the missing and such was caused by the sheet metal washer on the pressure reg housing being missing. All oil leaks were either stopped or minimized to near nothing.
Yesterday I made the same trip, with same trailer/load. Guy behind me tells me my truck is blowing blue smoke, and that it smells like oil burning. Even at 75mph he can smell it behind me. Get to parking area, same place as before, let it sit a while and cool down. Check oil-2 gallons low again. Refill and start home, watching the smoke in the mirror I determined that when I'm pulling hard it smokes bad, real bad. Stop about halfway home and check oil in a Wal-mart and its a gallon low. Refill and while refilling I notice that there is about a gallon of oil dripping from every square inch under the truck, and about the same from under my trailer. Get back to Lexington, take trailer to my shop, unhook and go to car wash to spray undercarriage down.Looks like I ran over a barrel of oil there is so much under there. Get it cleaned up-sort of, drive home Check oil 1 gallon down. My guess is the smoke was from the oil on the pipes.
I refill AGAIN, and drive the truck about 100 miles unladen last night. No appreciable leaks, oil on full mark on dipper sticker. After climbing around under it I have determined the oil stick is not the culprit, it is dry. Valve covers appear to be dry, even before sprayin it off. Look into intake area at turbo-dry.
Guesses please?
Guesses please?
