Seats...
kgb
Vernon, BC
I have a single cab 95 psd, and I'm looking to swap in two bucket seats from a 99 super duty, is this even possible or is there a kit I can get to get the mounts to match ? Any help or suggestions would be awesome
jsnyder7.3
Amelia, VA
If you can't find anything by searching on here (search tech articals) I'm pretty sure there is atleast one article on it. If not check the nation I know there's many SD seat swap articals.
Diesel_brad
Dunce
gilbert pa
I put a 99 Sd seat in my buddys 97 F250HD.
IIRC i used a piece of 2" square tubing as a riser to run from one side of the seat to the other across the front of the seat. I bolted that tubing to the seat frame. I then used his 97 seat brackets. I attached the brackets to the 2" tubing in the front and to the seat frame in the rear. The rear of the seat could of used a 1" piece of tubing as a riser, but my buddy is 7' tall so with the rear a lil low it gives him more head room and kinda reclines the seat for him. o and it is NOT a dirrect bolt in
