jsm1573
So I have a Frankenstein OBS truck that I am looking to put an SD 7.3 into. It is a 1997 Ford F350 4x4 CCLB w/ the 7.3 and a ZF5. Originally the truck was a 2wd automatic dually and I installed the suspension from my old 94 f250 along with the bed and ZF5 to make it a 4x4 5 speed truck. Now I have a 7.3 out of a 2000 f350 and I want to install it into my OBS. I need to know everything extra needed for this swap. Such as do I need a PCM/IDM from a SD manual truck or can I use the PCM/IDM that I have. And will a clutch designed for a SD 7.3 work with a ZF5 from a 94 OBS? Any other info would be great too. Thanks in advance!
