Ring gear question
Kevin 007
Full-floater
Nelson BC Canada
I will be helping someone with a ring gear replacement in an 86??? 6.9l Its slowly getting worse, the starter will grind on it every half a dozen starts or so now. And its not a starter issue as he has had different starters in it just to be certain that they were not the culprit.
Anyways, I have never done a ring gear on a 6.9/7.3 before. Are they the same as any other ring gear in the sense of replacement? Heat them up to expand, tap it off the flywheel, heat up the new one and place it on the flywheel and let cool?
That's how gary has explained it.
Also stick the center section in a frezzer while you're heating the starter ring.
Depending on price and auto or manual, could be money better spent to just get a new flywheel.
Oh and I think you could just cut the old one to split it off.
Sent from my USCC-C6721 using Tapatalk
This starter ring gear only comes off the standard trans flywheels or the heavy cast iron C6 E4OD wheels. If your replacing it watch for the bevel cut on the gear. That MUST be directed to the starter or said starter will never connect to the gear. Drilling a couple of small holes in the gear and then using a hammer and chiesel will break it off the wheel. Heating it up will also get it off the wheel. This is a known issue with the idi engine. Our funny firing order causes the engines to start and stop on 3 places on the gear. Those areas wear out and you have the grind issue. A cheap easy idea is to warm up the gear and rotate it around on the flywheel till new teeth are in the used worn out teeth area. Just mark the wheel so you know how far to move the gear. This will last as long as the original gear teeth lasted. But knowing how deep this job is you may want to change the gear. Be sure to use thread sealant on this crank bolts too. the enter the oily side of the crank and oil will leak out past the tight bolt threads. This has happened to several members too. I wash off the threads in the crank flange with brakeclean being careful to try to keep as much out of the oil pan as I can. Or just drain the oil after you wash the threads out into the oil pan. I use blue loctite as thread sealant because some members have sheared off all those bolts before. Seems they can loosen up. Happened to a few good mechancial members here too. Lets see if they will respond that this happened to them...:sly:angel:
Kevin 007
Full-floater
Nelson BC Canada
Great note on how these things start and stop at certain locations plus the thread sealant on crank bolts. Learn something new everyday!!! He sourced out a new gear somwhere so we will end up putting that one on. But the spinning the gear around on the flywheel trick is a good one to remember if a guy is in a pinch. Im planning on having my own tranny out next year for various reasons and I just might spin my gear while im in there....I had it grind one or two times but every idi I have owned has done that on rare occasions. It all makes sense now!!
JunkCowboy
