Replacing suspension
u2slow
bilge rat
Coastal BC
Check Amazon and rockauto too.
I didn't notice any improvement going from rancho 5000's to bilsteins. Ymmv.
RSchanz
Petaluma, CA
Ok cool thanks! At the moment it's just riding with some rusty super old maybe not even functioning shocks so anything will be better.
Black dawg
sw mt
The bilstein 5100 will be much firmer than an oe type shock. The 4600 will have similar or better ride than stock and will last.
rwk
S.W. mich
Just put new stock leaf's, track bar bushings and yellow Bilstein's on this D60, grease zerk in rear spring bolt, had to cut OG bolts out to replace, never again!
rwk
S.W. mich
Timbrens also, may have to extend them tho, think they should touch stop or almost touch.
RSchanz
Petaluma, CA
Are your rear shocks these 4600? You had to cut the bolts to replace because they were stuck from age or because of a fitment issue?
Noted. I found that rockauto had 4600 and said they fit, seems more trustworthy than 4wheelparts anyways.
rwk
S.W. mich
Had to cut bolt's on front spring rear mount, pics are of a leaf spring front end with Dana 60 axle, shocks bolt right up, not rear. Try tire rack also for Bilsteins, they have good prices on them last I knew.
This is the proper way, Bilstein use the labels for orientation, Bilsteins for my VW have the stem on the top, it varies with application, boots on these have drain holes at bottom, otherwise shock doesn't know which way is up! as long as it has same mounts at each end.
Noticed my shackle photo was the front, put grease zerks in those also!
RSchanz
Petaluma, CA
I'm planning on leaving the leafs in and just doing shocks. No springs on my truck so should be easy...
RSchanz
Petaluma, CA
I ended up going with the Bilstein 4600 shocks purchased from Rock Auto. Probably regardless of what shock you end up with I came up with a good technique for installing them that I didn't see or read anywhere else. I installed the bottom bolt first then used a ratchet strap to compress the shock then get it over the top bolt. See photo:
Big Bear
