Rebuilt Injection Pump Installed now low on power
Ranger5.0L
waterloo,ia
93 7.3 tubro truck just installed new IP but has less power than before. It seems to start and run great other than having no power. Egts stay around 5-600 even with a load on it.And even lugging the motor wont smoke at all. Boost is down a bit also. Any ideas what the issue is???
It really needs to be timed with a meter. How did you remove and replace the injection pump. If you removed the pump still connected to the gear and cover you may have it off timing in the gears. If you didn't remove it that way then you surely need to time it. I have a timing meter rental program I offer to any member of this forum. I send the tools needed to time your engine and all the instructions plus my cell number. The fee is $60.00. Contact me thru a pm if interested. But please.. Get it timed if you can find someone that will do it. Also do not pay for some so called mechanic to time it by ear and charge you for it... If you findsomeone thats going to time it like that please send me the money they charge. You will egt the same result... Money out of pocket and nothing back for it. Ask for the pulse type timing and have them set it for 9 to 9.5 degrees before top dead center. Ford factory specs are 8.5 + or - 2.5 degrees... Thats not what the old guard here feels is accurate enough. My Kent Moore J33300 meters will time down to a 10th of a degree. They are a micro processer cumputer that does this very well. At this time I have a meter in the Pa. area and it will be ready to move on in a few days. Out here on the west coast of Ca only one location I know of offers pulse type timing and last year their charge was $120.00. I'm betting its more this year. Three years ago it was $60.00....
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
It's probably set up for a NA truck, so turn it up a bit (do you have a pyro gauge?). And it really needs to be timed.
Ranger5.0L
waterloo,ia
Didn't pull the oil fill cover so that's not the issue...timing should be close enough to run decent and it does but its just down on power
Devon Harley
San Diego
I would turn it clock wise with a 5/32 al wrench (towards you) and 1 to 2 flats makes sure you have a pyro gauge on it jus did mine it's running good now not to much smoke tell she's floored
Wyreth
Certifiable Noob
Las Vegas, Nv
Your pyro will tell you how much to turn up the fuel. Personally I would turn it up a flat at a time, going out and giving it a good flogging test drive between, and watch your EGT's. Once they get into the range you're used to, you've turned it up enough. 1100 I think was the 'hoshitnomore!' number, but I could be wrong.
However Gary is right. You may be timed close enough to run ok, but it's not going to give you what you want outa the peddle till it's timed right. Renting his timing meter ish cheap insurance.
Ranger5.0L
waterloo,ia
Turned up one flat and drove it didn't seem to do much guess I'll try a couple more and see....yes i have a pyro and boost gauge it use to hit 12 psi while towing now only seeing around 8. i realize timing it is needed for max performance and i will get it timed but i don't rent tools I'll have to see what i can find to buy. thanks for the help so far guys
Wyreth
Certifiable Noob
Las Vegas, Nv
A NA pump is going to be rather under fueled for a turbo, so as long as your EGT's are ok, and you're not "rolling coal" you can give it more fuel. Just make sure you watch what's happening as you do so.
Also, if you're feeling adventurous, you can try bumping the timing by ear. Turn it a dimes width toward the passenger side, tighten it back down, (go ahead and hotwire the cold start advance) start and listen. Rinse and repeat until it starts to rattle like a powerstroke, then stop. Pull off the hotwire and it should be close. This can get you into trouble tho.
Get it timed! That has way more to do with performance then fueling does. Did you know that maximum fuel delivery occurs at 1400 RPM (max throttle)? Everything beyond that is all timing related!
f-two-fiddy
Duluth, Mn.
I concure with Mel. I've always said that proper timing makes the difference between a satisfied IDI owner, and one willing to sell.
Ranger5.0L
waterloo,ia
Ok guys i get the point I'll time it like I've already said i will once i get the fueling or lack of problem fixed....with that said I've turned the screw 3 flats now and its getting better but still see absolutely no smoke even under heavy load and egts are still low so guess I'll be turning it some more..
pwillis
