Rebuilt 0 mile 6.9, $1950, PNW
jaluhn83
Upper Marlboro, MD
Fresh rebuilt Ford/IH 6.9 diesel long block / 90% complete engine. $1950. Seabeck WA.
Late 84 block (sn 105xxx)
Bored 0.040 over
New main, rod & cam bearings
New pistons & moly rings
New lifters
Good used late model (steel bridge) rockers.
Rebuilt heads w/bronze guide liners, new exhaust valves and ground intake valves & both seats.
New water & fuel pump
Rebuilt & hydroed oil cooler (pickup style)
New motorcraft thermostat
New stainless freeze plugs installed with Ford type tool (not just hammered in)
Would need an injection pump, injectors and accessories. I have a good used starter, alternator & vacuum pump I can include.
Used injection pump available for $250.
Was going to rebuild this to replace my truck engine but wound up getting a later model 6.9 block to use instead.
Knuckledragger
Payson, AZ
Did you replace wrist pin bushings? Balance rotating mass? I am going to need an engine, the price is pretty good.
William88
