rear tank option
Greg5OH
MI
Rock auto lists a natural colour steel 19 gal for 78, or a black painted 18 gal for 80 or so. Both for diesel.
Whats this of 33 gal ones i keep hearing about? Id like that! Is it from a bronco? diesel compatible? I need info!
My rear tank has a leak somewhere around the seam so she gotta go. probably get a new selector valve too as i dont think this one has been used in years.
Two tank options besides the factory 19 gallon.
a Bronco 33 gallon one or a 38 gallon factory optional one for trucks.
Bronco's had plastic tanks so that would work for diesel right?
Needs different fuel pick up and so forth but ya I was ...WAS going to do one.
There ya go.
Al
Greg5OH
MI
for bronco only showws steel, and doesnt mention capacity
whats this one?
PLATINUM PRO Part # FTK010047
and i dont see a 38 gal option for the truck.. unless its for CandC?
NO_SPRK
User & Abuser
Santa Rosa, Ca
LMC sells a 38gallon drop in truck style tank. putting a 33gal bronco tank in will require some work.
Greg5OH
MI
Ouch 200 for tge lmc tank. will stock tank straps work? Literaly drop in?
Al, are you now going to do something different with your fuel tanks now. you make it sound like you scrapped the bronco tank idear....
Appears I have to bad Bronco tanks...which just sux nuts...thus the increased fuel capacity plan is on hold until I can either ONE fab a custom 40-45 gallon rear tank, get a Bronco tank or the larger 38 gallon model.
All on hold as I've had some bigger fish to fry...
Sgtbyersfw
