Rear Shackle Flip thoughts
MasterChiefIDI
Mississippi, USA
I am wrapping up my D60 swap using Sky's SD RSK for the front. I am considering options for lifting the rear. I've seen Sky's SD rear shackle flip kit. Suppose to improve ride quality but I don't want it to squat real bad. Also don't want to cause axle wrap with blocks. This truck was factory 2WD→4WD so the rear didn't even have blocks from the factory..
Has anyone here had experience with a rear shackle flip? What do most folks do to correct the rear height after installing Sky's RSK kit up front?
u2slow
bilge rat
Coastal BC
If the fwd end hanger on the rear spring is dropped accordingly (i.e. leaf stays level) that really minimizes any downsides.
If not, then the pinion tilts up... causing driveshaft/ujoint issues and possibly handling issues when towing.
Blocks are used on so many factory trucks. It's not a big deal until it's excessive block with too skimpy a spring.
MasterChiefIDI
Mississippi, USA
They make tapered shims it seems to correct the pinion angle when doing a rear shackle flip..
Good point on the blocks. Seems they are used all over the industry. I'm thinking if sky's RSK up front adds 2-2.5" from factory 4WD, that'll be more like 4-4.5" of total lift for a 2WD. This would equate to possibly a 3-4" block in the rear to level is my thinking.. But if the Rear shackle flip kit is highly recommended, I'm down to do it especially if it reduces wrap/wheel hop. Just don't want it to squat under load terribly. Would like to pull a bumper camper down the road. Then of course there's air bag lift..
Smitty 90idi
Army
California
all the old jeeps and many old Toyotas have shackles down in the rear. I’ve done many of off road trucks and suvs in the past. It does help in ride quality and articulation. However I’d never tow with it personally. I know many guys that do. But not me.
u2slow
bilge rat
Coastal BC
It won't squat if setup proper.
I run up to 2tons payload in my Dodge with a homebrew shackle flip. But I kept the leaf spring level.
edit: also pull a loaded 8000# car hauler occasionally.
MasterChiefIDI
Mississippi, USA
That's pretty wild. It doesn't squat? What are your springs rated for? My factory springs are 2800lbs each and it'll squat with 1000lbs in the bed in the factory set up.
MasterChiefIDI
Mississippi, USA
I reached out to Tanner from Sky and he shared the following which I thought was very helpful:
"I would recommend the 08-16 SD rear spring swap kit and putting helper bags on the rear if it does squat too much. You could also just do blocks but it won't improve the ride quality, you shouldn't get axle wrap unless you take off aggressively. I have the shackle flip and 6" blocks on my personal obs and only get axle wrap when I get after it at take off with a heavy load.
To keep it level without blocks you would need the 4" kit with the stiffer rear springs but if you wanted to do the softer rear springs you could either do the 4" kit with a 2" block or the 4" block with the 2" kit."
I think if I were to do skys shackle flip kit, I would do the stiffer 43-1705 3600lb spring with the 4"kit. It seems these springs are very expensive from Ford, around $600 each with shipping and dorman being $333 each. Plus $1100 for Sky's kit, plus shocks, longer brake hoses, end link extensions, ubolts, carrier bearing spacer.. it adds up quick.
I may do 4" blocks for now and see how ride quality is and go from there. I will have to do something eventually as the truck squats too much as is so either bags, stiffer springs, or this Flip kit..
u2slow
bilge rat
Coastal BC
They are stock '95 2500 springs with an add-a-leaf.
They are pretty beat up now, so finally squat a little. Shackle angle matters. I have some beefy custom leafs to put in next.
03wr250f
Hamilton/Montana
tanner has a very nice obs, 205/30? injectors, turbo upgrade, intercooler, e fuel etc etc, and i believe he is on wide 38s currently.
My point he is knowledgeable, has experience personally and professionally, and has a 7.3 psd that makes right near 500whp, on large tires. almost all obs axle wrap, but if set up properly they dont, and dont need traction bars(as someone who has traction bars)
ROCK HARVEY
Dayton OH
If you go with the 4” rear blocks, I recommend the cast ones and not the welded ones. I bought two welded sets from two different manufacturers, and both were warped on the axle mount side from improper welding technique. After returning the second set I bought some cast ones and they are flat.
MasterChiefIDI
Mississippi, USA
Interesting. Was one of the manufacturers you tried Sky? Where did you find the cast blocks... Thanks
ROCK HARVEY
Dayton OH
I can’t remember who the first manufacturer was, but the second bad one came from superlift. Here’s a screenshot from a video I took showing the warp in the mounting surface. If you do buy a welded one, just check it for flatness first.
The cast ones came from Amazon, here’s the link: https://a.co/d/0bjTVpSG
bneumann22
