Rear Fuel Tank Parts
jhenegh
Truck Still Earns its Keep
Deerfield, WI
Hey Guys,
My 1994 F250 currently has no rear tank at all. PO dropped both due to rust/leaking but only replaced the front tank. I'd like to finish the job with this:
http://www.amazon.com/dp/B000C7TW5K...TF8&colid=3E1PECZ3FN9LE&coliid=I2MPOGEL6DFY1S
That's the tank I found on another thread here.
My question is, what parts do I need? I still have a functioning selector valve and all the lines, but no filler neck, sender, straps etc. I've looked at a parts diagrams but having no old tank to reference I'm just getting a bit confused. Mosty confused on what parts I need in-tank.
Thanks and have a great Thanksgiving!
dunk
Dunce
NJ
I just ordered that tank but have not put it in yet. Note that it does come with the hardware kit. Includes longer bolts/sleeves/spacers for straps or skid plates and tubes to extend the pickup on the sender. I may use those or may do the compression fitting and tubing eliminating showerhead or sock filter as others have. I wasn't sure what hardware was included and luckily did not order the hardware kit or I would have had two.
You'll need straps, fill tube/fill rubbers/hose clamps, sender/pickup, rollover valve and grommet. The sender/pickup will need the lines extended for the deeper tank. I recommend drilling out the rollover valve and using a larger vent line, vent to the filler neck at top and tee in that line near top with 1/4 to atmosphere or make sure you vent to atmosphere somewhere in the system. There are several threads outlining this mod, it fixes slow and difficult fill up problems fuel or foam backing up the filler before the tank is full.
My suggestion is find what you need in a wrecking yard. The only real differances in rear tanks is the size of them and the dually fill necks. Otherwise any truck rear tank will be a good fit. Just try to make sure the wrecker tank is a diesel tank. A smell from the fill neck will tell you that if the engine is gone. Even then the dash gauge should tell you diesel only and the tags above the tank fill will say that too. Straps are dependant on the size of the tank too so if your installing a larger tank it will have spacers or longer straps.
Sgtbyersfw
