RKOCH said:I have been scavaging on both of mine for several years., I welded a pipe nipple in the exhaust and screwed a ford anti backfire valve from a 460 in it and plumb the line. It evacuates the crankcase well and helps keep the crankcase in a negative pressure atmosphere. Weld the nipple at 45 deg screw on the valve and plumb the line it works well and all the BB fumes are out the tail pipe.
I didn't know where I wanted to put the E-vac fitting, untill I decided to remove the race bullet muffler and put a straight pipe in ! So I made up a pipe with the fitting in it and just placed it where the muffler was and ran a hose back to it from the Banks fitting .
towcat said:here's the pic....
one other thing to think about is the type of hose you are using. standard rubber heater hose is good but will fail in a short period of time due to the fact that heater hose is not oil rated. there is a high temp silicon hose availible but not cheap. One more thing, any anti-backfire valve will work so the trip to the stealership can be avoided.
SIKPUP said:OK, I finally got tired of the blow by vapor, and turning off my heater each time I got to a red light, so the vapors wouldn't come in the fresh air ducts and blow vapors inside the cab !I didn't know where I wanted to put the E-vac fitting, untill I decided to remove the race bullet muffler and put a straight pipe in ! So I made up a pipe with the fitting in it and just placed it where the muffler was and ran a hose back to it from the Banks fitting .
So far it works great, no really noticable vapors, maybe because it sucks all the time and they don't build up, so they aren't noticable when you stop !
It's only been done a few days so I'll keep an eye on it ! Sounds really nice with the straight 3 1/2 pipe.
Next I want to build a double cone air filter inlet pipe to feed the turbo with fresh air from the back of my cowl hood.![]()
Mike![]()
Agnem said:EZ, somebody was going to send me some fittings, and I never got them. Since I don't mind the RDT fumes, I've pressed ahead with my Exhaust system for the Moose Stang without worrying about the RDT at this time.
The Warden said:BEAUTIFUL!!! Thank you for playing guinea pig...
A few questions. First, about how much blow-by are/where you seeing?
Second, see any oil leaks yet? Were you able to determine if the exhaust is putting a vacuum on the breather at all times, or what?
Third, about how far back was the muffler on your truck? i.e. about where in the exhaust did the bung go?
Fourth, any pics?
I'm about ready to order my exhaust, so if I'm going to do this, I plan to order the parts today. IIRC the hose nipple on the Banks adapter is 1" or so; did you have to step down the size? If so, where (although I'm guessing that you did it at the exhaust)?
Thank you SO much...![]()
sle2115 said:Uh, that somebody was me and as far as I know, they were sent!!! I will start doing some checking because I just assumed you had received them. I will let you know what I find.
I guess at this point, if you are proceeding without them, and I find them, I will just try to see what I can do. I sent some stuff out (like the cab mounts purchased on Ebay by another member here) all at the same time. Everyone else received what I sent. IIRC, I had my wife deliver to the post office, I will see what she has to say as well.
Scott
