randomly hard starting this afternoon.
what do you think it is?
  • Total voters
    10
  • Poll closed .
homelessduck
My guess is coolant in cylinder(s) after it warms up, but hopefully I'm wrong ! :D
that is the diagnostic.
i have a long weekend of picking up garbage. funfunfunFUN!!!
if California would abide by the constitution of this here country, i would be doing an engine swap.
time to go make my 141 dollars a day!!!:puke:
If you think there's coolant in a cyl. and know which is the suspected one, pull the GP out of those 2 cyl's. coolant should pop out if there's any on a start up. Takes a little work, but. When the damper pulley mark is at 0 #1-4 is at TDC, and each 1/4 turn from there will be 2-5 --7-6---3-8 @ TDC. You could let set half hour on a hot engine between each GP removal. Just a troubleshooting method.
With the oil only having small amounts of water in it, it only seaps when hot,
I think I've pretty well figured out what's wrong.
Heads need to come off. And soon before it destroys the short block.
I will I spect further after the heads come off.
Most likely I will pull the engine and do the work.
I was never very happy with the looks of the
Engine compartment anyways.
I'd like to delete those pos plastic inner fender wells and make some aluminum ones.
Paint the engine compartment
And make it look nice this time.
bobs_idi
United States
Aluminum fender wells? you got my attention
jhenegh
Truck Still Earns its Keep
Deerfield, WI
How funny we both got head issues the same week? Dropped mine at the machine shop Tuesday. I guess we can keep track of each other's issues and progress. Yippee haha
loads of joy! lol
ill find out monday which avenue i will take.
aluminum fender wells would be pretty cool.
making the engine compartment look awesome
will be the ticket!
Big Bear
