Quick alternator question
skeeter72
lexington KY
Good Sunday morn gentlemen. I have quick general question about replacing an alternator. A buddy I work with was asking me how to do it and I told him it's just bolt on basically. I also told him he should remove the negative wire before the positive. Is that correct? I remember a couple years back someone told me that was extremely important. However I can't remember if I am mixing the sequence or just making that up because the coffee has not kicked in yet.
Sent from my iPhone using Tapatalk - now Free
smolkin
Stuck inside Mobile
Mobile, AL
Remove negative(s) first, I guess, only reason I think is it lessens the chance of a loose cable flopping about and touching something it shouldn't. If you take a positive off first, the system is still live until you disconnect the other positive terminal at the other batt, and the loose one could easily touch a grounded part. Flopping negative is OK as long as it dosen't touch the pos batt terminals.
The above is correct. Another way of thinking about this is removing the positive cable at the fender mount solenoid and the positive from the passenger side battery will kill all power to the truck. Caution needs to be used around several always hot items on the trucks. The starter is always hot. The alternator is always hot and so is the glow plug controller. Not believing this just trace back the wire from the alternator to the fender solenoid and then follow it to the battery. Now think about all that power and amps from 2 big diesel batteries grounding thru that small wire. It will burn it off quicker than you can let go of the wire.
ifrythings
BC
Another good reason to do negative first is if your wrench touches something, your not going to be shorting out the battery, but if you do the positive first and your wrench hits the rad support for example, well lets just say that's not the ideal way to arc weld wrenches to things :rotflmao
Another good reason to do first. ive first is if your wrench touches something, your not going to be shorting out the battery, but if you do the positive first and your wrench hits the rad support for example, well lets just say that's not the ideal way to arc weld wrenches to things :rotflmao
Your screen name says it all. LOL
Technically the sequence has to do with newer electronics.
Computers CAN be fried if you hook the negative up first.
Alts/VR can be fried.
But if you just disconnect the grounds, you're good to go. Even if something has power stored, it can't ground anywhere.
JunkCowboy
