Questioning Orfice tube Installation Direction
I'm repairing my ac system on my 79 chevy truck. I found the orfice tube installed with the long end in last and the short end in first. See the pic. Did someone installed it wrong many years ago. The long damaged end was sticking out and I damaged it removing it. I do understand that happens sometimes too. Which end goes in first. The short end or the long end. I'm refering to ththe o ring determining the long and short of it. Well hell. I can't upload a damn pic.. Forgotten again how too. My life sure sucks today.. Will try again later when I figure it out...
Dave Barbieri
Overton, TX
You'll notice that the short end has a couple of tabs that stick out. This lets an extractor tool lock onto a stubborn o tube and pull it out. When the "A/C tech" installed the tube backwards, he gave up that option. There's other ways to get out a stuck/damaged orifice tube, but they're all a pain.
chris142
SoCal
The large filter end goes in last and the little 1 inch long filter goes in first. The refrigrant gies from the compressor to condenser then to the tube in the evap.
theguruat12
Certified Tinkerer
Albuquerque, New Mexico
Still not sure which way it's supposed to go in since I didn't see it (I did the compressor and accumulator myself and had the shop do the orifice tube for me) but mine was in backwards before, and when my old compressor blew it shot half of the damn thing into the evaporator. I had to spend an extra $110 on an evaporator I didn't need just because whichever idiot before me installed the stupid tube in backwards.
End rant.
chris142
SoCal
It goes in the lower evap on that chevy with the short end in first
Dave Barbieri
Overton, TX
Gary, Chris is right. ;Sweet
I was telling you stuff bass-ackwards. Sorry for the screw-up! Coat the o-rings with refrigerant oil and load it like a cartridge in a rifle. Short end goes in first, pointing towards the evaporator. Long end (with the tabs) goes in last. The tabs are the last thing you'll see. Give it a small push to be sure the o-rings are seated and you're good. One other suggestion - soak all the o-rings in refrigerant oil. Some folks put all the o-rings in a baggie, add some oil, seal the baggie and let it sit a few minutes. For small jobs (replacing an accumulator/receiver drier or orifice tube) the oil cap works great.
JunkCowboy
