idi traveler
I have a well pump w/5 gal pressure tank. Can anybody tell me if that would be good for a filter set up for WMO?
I guess I could give it a try. If it eats up the pump I can always replace it with a pump that will hold up. Ant ideas on an affordable gear pump?
I have pumped alot of hot or cold vegetable oil with one of these pumps
http://www.harborfreight.com/1-inch-clear-water-pump-1479.html
nate
350 chevy oil pump driven by a drill.or big block pump if you want even more flow.
my SBC one will pump about 50 gallons in 10-15 minutes at 1000 RPM depending on the temp.
you have to modify the pump so that the ports have tubes in them.oil does leak a little bit from the shaft though.
or you could use a power steering pump as well.
I use a PS pump from a 1986 Honda Accord for my setup. Not the fastest pump in the world, but it has lasted me almost two years...
got any pictures of your setup?
