Pulls to the Right, Then Drives Straight Again
SlimF350
Bloomington, MN
All,
My problem is my 1994 F350 CC SRW pulls hard to the right (mostly at freeway speeds) then it's as if something frees up and it starts driving straight again. It only use to do this every once in awhile but now it does it all the time. The truck has 300k mi on it, so the likelihood of something being worn is obvious. I just don't know what. The front tires don't have any uneven wear, but I could use some new shocks. Thanks for any help!
Slim
itsacrazyasian
residentcrazyasian
boca raton, fl
jack up the front end and give everything a good shake to see if theres anything worn. Grab the tires and shake side to side to check steering linkage, then up and down to check ball joints.
Do you have a steering stablizer?
It may be binding.
jimmyB
MELBOURNE FL
Mine used to do that,found out my pivot bushings was shot.Replaced them now it rides good.
Black dawg
sw mt
jack the front end up, lock the hubs, spin the tires.
sounds like a binding u-joint
if those pass inspection, with front end jacked up, start engine.
could also be steering gear.
SlimF350
Bloomington, MN
A binding u-joint? I'll get the front end up this weekend and let you guys know the verdict. Thanks for the input.
Slim
typ4
Newberg,OR
Sounds like mine when the wheel bearing was trying to sieze.
randomq
Richmond, Virginia
I think I'd be checking the wheelbearing first. Then brakes, then the rest of the front end.
Check the bearings and brake on the rear of that side too.
Goose_ss4
ca
does anybody know the torque to the wheel nuts in the hub off hand?
Goose_ss4
ca
not the lug nuts, but wheel nuts inside the hub. hold the rotor on the spindle
Studebaker62
