PSD into 92 IDI. What'll I need to make this a painless swap?
h2odrx
Anti-O
Coastal Neckville, NC
Well if he needs parts for his swap ok, Hijack a thread :D
PM coming?
Yeah, lots of parts. Is there anything in particular that you are looking for.
Wait, did I just hijack the thread? OK, never mind that.
Just PM me if there is something you are looking for and how much I should sell it to you for.
94f450sd
somewhere,ma
here are pictures from my 94 when the dash wireing burnt and i pulled the dash to fix it.hopefully you will find something usefull there.
ne_plus_ultra_1
FLORIDA
Wow, you took out the aluminum column support bracket as well. Why'd you do that? Toast some wires not on the main harness?
94f450sd
somewhere,ma
i smoked wires all the way up behind the dash cluster and over behind the radio.couldnt find a harness for it either.had to sit in my living room with a soldering iron,solder,shrink tube,couple different color rolls of wire,cutters and tape and make the whole thing one wire at a time myself cuz i burnt almost everything behind the dash :eek:
94f450sd
somewhere,ma
well it also had the typical ford headlight switch wire burnout from the previous owners that was fixed with a toggle switch that i then bandaided with a relay so they atleast turned on with the headlight switch.so at the same time i took care of that problem and permantly wired in a relay for my running lights not that i need one when im running all but 2 LED bulbs in the rear now.
pwillis
