PSD glowplug relay
greenskeeper
PA
While you're at it, wire in an LED from the hot side of the relay into the cab so you can see GP operation, then add a switch breaking the ground wire going to the relay to save you glow plug system from operating when it's not needed.
Randy Bush
Great Falls, Mt
Change the rely and trucks starts like it should. Didn't do the White Rodgers , didn't have time to wait and need the truck for work. Tore the old one apart and could see that it was bad with not doubt. Will have to order the White one for down the road.
William88
