PSD glow plug thread pitch
Kevin 007
Full-floater
Nelson BC Canada
Needing to clean up some mangled threads in 1 glow plug hole. Wanting to confirm thread pitch before I attempt to make sure I have it 100% right before I make it worse.
Im getting conflicting info about the threads being 10x1.0 vs 10x1.25
Any insight?
Mrrusty
Florida
Motorcraft ZD9 is M10 x 1.0
Im sure you already know this but I wouldn't chase a thread while the heads are on the motor. The chips will fall into the pre combustion chamber and damage the pistons / valves.
Here is the BERU GV823 Glow plug for FORD USA F-250, F-350, ECONOLINE
https://www.autodoc.parts/beru/7020165
Kevin 007
Full-floater
Nelson BC Canada
Thanks. ZD9 is an idi plug however. The ZD11's in a stroke, are different. The threads of an idi plug will bind when trying to turn them into a powerstroke head (just as to test thread fitment)
