Proper Use of Timing Meter
A member asked to see the viedos I made on using my timing meters Enjoy..
The magnetic probe goes in the dampner tab. There are 2 locations down there. We use the tall skinny port. In my timing meters that are rented out I send along a 5/16 drill bit to clean out the crap that collects in the skinny probe location. The other probe is the injecter line clamp and its placed on either cylinder 1 or 4. they both time the engine exactly the same. Some engines time better on cylinder 4 and I don't know why. All vans are timed off cylinder 4 because its easier to reach. My meters can time off any cylinder if you know the offset. The microprecesser in the meter does the offset for you or you can do it yourself to use any cylinder. You connect these 2 probes. Power the meter off the battery. Press one rocker switch. Start the engine and rev to 2000 rpm watching the rpm and degrees of timing on the meter digital display.. Really simple. Also in the timing meter is the 2 tools required to move the pump and loosen the nuts holding the pump tight to the gear cover. Really easy to use actually.
bneumann22
