Hey all,
Got in the truck this morning and the wipers weren't even touching the window even though I cleaned the ice off so I was already frustrated...
Go to leave and it doesn't want to go into gear. Finally shoved a little harder on the clutch and it went into gear. The whole way in you could feel it not completely releasing. I've always had to push it a smidge harder than I thought I should to get it to start.
I haven't seen any firewall cracks, and the linkage at the master looks fine, but I do sometimes have an odd noise (almost a pop?) from the dash when I push the clutch in.
Where do I start with this after I check the fluid? I would normally just replace the clutch to find that wasn't the problem anyway but I would like to actually diagnose this for once.
Clutch has always been firm. I drove another one once and his pedal felt like a car, makes me suspect the clutch....
How hard is it to get to the linkage under the dash to inspect it?
