Powerstroke zf5 to 92 Idi swap
Christopher Cline
Washington
So I have a 97 powerstroke donor single cab and a 92 Idi crew cab. I know now I will have to use Idi clutch flywheel and pressure plate, would the pedal assembly master and slave work? Also drivelines just get mine lengthened or will I need flanges from the powerstroke welded onto my drivelines?
Christopher Cline
Washington
No need for flanges, just adjusting length if need be. They are both obs so the pedal assembly will work as well as master and slave cylinders.
Could I use the front half of the donor rear driveline and mate it to my rear half....in theory it would work right?
