Power Window to Manual Window?
Heh, no worries. When he was talking about knockouts, is there just a piece of metal on the frame I could remove and put a manual crank in it?
there's a outline in the plastic door panel for the circular cutout for the regulator hole.
as far as the door shell, it's setup for manual or power windows. all you do is add or delete wiring.
i will post pics shortly.
KZF250
Denver
I have power windows...Drivers side window is good for now, passenger needs to be slapped now and again. Locks don't work...pnumatically controlled??? Maybe just a bad hose.
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
Nope, lock are an electric actuator. I think it that age of vehicle, you can replace just the actuator. I had a 98 Sable Wagon and the actuator in the hatch was weak..... you had to replace the entire latch mechanism to fix it...... I just used the key when it was "in a mood".......
mntwins7
Broken 6.9
USA
So will I need a different regulator?
I think this is the hole where I would put the crank
Koch13351
SoCal
My '84 has power windows and locks. Actuators seem like they'll punch a hole in 1/2" plate. Windows, well, they need love. Kinda sluggish and need a helping hand once in a while. Can't go to manual windows now as I have re-engineered the doors for 6x9 speakers. I'd make sure to make whatever system you go with new. No sense in using used wear items.
freebird01
Post Turtle!
Fort Wayne, IN
in a truck that the a/c doesnt work the last thing want to do is constantly lay across my seat to put the pass window down... i just converted my front doors to electric....no looking back. just make sure the replacement motors you use are the ac delco motors. the cheap silver motors dont have near the power
dunk
Dunce
NJ
If you want a drivers side regulator brand new for 80-91 let me know I have one.
pwillis
