ALREADY A FACTORY DONE DEAL!!!
....except it wasn't Ford who did it.
For awhile, the Vikings made an engine that had both sc and turbo installation.
Volvo made a boat engine with this very application because on boats, we have to dig our way out of a hole before getting our craft up to cruise.
The SC pulled us out of the hole in no time and shut off electrically once the engine started spooling up the turbo. There was a cross-over point when the turbo totally took over.....yes, around 12-1500- depending on throttle position, engine load etc.
There are plenty of 12V electric clutches that you can install on the front of whatever SC you choose. The dilemma will be to find the sweet spot for shut off for the application chosen. I could see where a tow vehicle could benefit greatly from the combo set-up or a snow plow with an SC only.
I'm not sure where the electric would hook in for automatic shut off, on the Volvo, the computer controlled the SC. With an all mechanical engine, I'm not sure where to plug in to, but there might be some type of turbo boost switch that could turn off the SC for mechanical simplicity.
BTW- Volvo stopped making the combo, not because it was a poor performer, but the fishermen who were trolling found out that the sweet spot was right smack dab in the middle of the power transfer between the two. It carboned up the engines pretty badly, and it also made for a surgieness because a boat never runs on a flat surface, always climbing and coasting up-n-down swells. Neither the engine or driver could figure out where the throttle should be. The fishers disconnected the SC's clutches with a manual switch, but voided warranties. Also, the fishers would load up the fuel system and really make carbon when the SC was manually turned off. The low end was lacking sufficient air for the injectors at low end.
When used as a ski boat.... no problems, always trying to get up to speed with heavy throttle, system worked as flawless as anything.
I'm a newbie IDI owner, so can't even guess where to start plugging in. I'm sure the smarties around here could figure out the system pretty easily. The mounting and getting it to work isn't the problem, it's balancing the fuel with the air for maximum performance.
Just a little different insight.
