Parts rig- lots of fun suprises! (lots of pics!)
DesertBen44
Grand Junction, CO
So now in addition to my 92 7.3 N/A F250 extended cab longbed 4x4, i am the proud owner of a 1986 f250 extended cab longbed 2wd w/a banks turbo.
I bought it honestly planning on taking the banks kit off and throwing it on mine maybe, the wheels are nice, and the seats are extremely comfortable. I figured i could take what I wanted and scrap/sell/whatever the rest. Turns out I got a little bit more then I bargained for.
Truck originally had a 6.9 idi motor, guy claimed it now has a custom built 7.3 in it, but with no receipts that really means nothing
Truck has a heavy built c6 transmission in it, aparently it has a gearvendors overdrive unit, rear airbag spring helpers w/onboard compressor, tons of gauges, shoddy wiring
everywhere.
Going to have to move parts fast as I live in an HOA until the thing is small enough to fit in the garage (bed off, maybe chop the frame, idk)
Anyways here are some pics, and if you want anything you see in the pictures a lot of it will probably end up for sale on here, at least stuff that is worth shipping.
its got these on both sides; anyone know what they are for?
has a pulley to take slap out of alt belt? ;Sweet
On firewall; not sure what it is my 92 doesnt have it
Racor water seperator, not plumbed into anything...
ugly but crazy comfortable bucket seats! might end up in my 92
c6 gear vendors adapter
some kind of air ride suspension job w/onboard compressor, shoddy wiring
gearvendors unit; hopefully someone somewhere wants it, dont think it would be worth it after buying an adapter and all for my zf5
finned transmission plate, some other plates like that hiding too.
Not sure what thats for, self defense?
Lots of other random stuff on this thing too, seems the owner before the previous owner put a lot of money into a truck that really isnt worth anything.
Truck clicks but wont start, so Ill get on that pretty soon so I can fire it up and drive it around make sure everything works.
Still not sure if I will put turbo in mine, would be cool but kind of worried it will ruin me not having to work on the motor at all so far.
All in all pretty cool that so many random parts were stuck on this thing, someone somewhere along the line really loved this truck!
DesertBen44
Grand Junction, CO
Not sure what that box was for...
Kind of scary wiring...
Poway, CA
Box on the front bumper might be for weights you would use if you were using the truck in a tractor pull. My guess.
Mike
flareside_thun
Reviving The General Tao
Tavares, Florida
Like said, the tabs are for a slide in camper, I think the bar across the front on the bed is too. I'm gonna go ahead and say that the box was a mount for a generator.....someone had the setup with that truck.
gandalf
Senior Member
CA &/or Maine
Yes, those are HappyJack camper tie-downs. The piece going across the bed, at the front of the bed, should tie them together, making them more stable in some way. HappyJack added that feature when the sheet metal in the beds got so thin and would no longer sufficiently hold against the stress from the camper when it wanted to move. There should also be a couple buttons back by the rear end, either in the outside bed area, or on the bumper. They're also part of the HappyJack setup.
The unit by all the wiring with a tube on it is a brake controller, Kelsey-Hays IIRC, tube is teed into master cylinder.
bobracing
Kennewick, WA
"gearvendors unit; hopefully someone somewhere wants it, dont think it would be worth it after buying an adapter and all for my zf5"
If you have a 4.10 truck, that would make a nice addition to keep the rpms down.
Poway, CA
Oops! Yeah, that box up front probably is for a generator, not tractor weights. My bad.
If you don't have plans for that alternator belt idler, I may be interested.
Mike
pwillis
