Parts clean out, gear vendors module, etc...
BlackNoma
Sweeny, TX
I completed a zf5 swap on my 89, so I'm selling everything from that and what I had laying around in the way. I'll be bringing all this to the idi Dyno/show and shine November 16th in San Antonio.
Discounted prices at the meet!
Idi 4wd c6. Regular driving was fine, but slipped/ran hot (220°) when hauling. It'll work but I would rebuild it. Comes with torque converter -$150
Brick nose auto pedal assembly. -$20
Stock bricknose diesel radiator. -$50
Pinhole leaking brand new G-plus all aluminum radiator. For automatic. Used for one week. -$100
Idi 4wd t19. Unknown condition, never ran it. -$50
BW 1345 t-case. Behind the t19. Unknown. Never ran it. -$50
Brick nose stock vac brake booster. Worked fine (swapped to hydroboost) -$20
Auto trans tunnel. Rust free, has a couple of small holes drilled in it. $10
7.3 auto flexplate. -$50
Gear vendors module and wires. Everything you need for the c6 except the GV unit. Part #1E171109 -$100
Other parts, odds, and ends I'm forgetting.
BlackNoma
Sweeny, TX
GV module doesn't come with the speed sensor or cable from the unit to the sensor. Forgot to add that.
