Anybody have experience with these M-pact ceramic clutches? What is the reputation of M-pact or the other brands of clutches on Rock Auto? SB is too pricey for what I need. I am hoping my build makes 300 bhp. I occasionally tow 8-15k.
300 bhp or 300 whp?
300 bhp is easy. 300 whp however - I want to see dyno results and a build sheet.
For 300 bhp, a LuK is fine. They hold up just fine, especially if you don't floor it and dump the clutch. Let the clutch out, *then* floor it and it won't slip.
(even dumping the clutch, they don't tend to slip, even at higher HP levels.
Also, I've found that some slippage can be caused by 'pump up' in the clutch pedal assembly. Make sure that you have just a hair of free-play at the top of the pedal so it's not pushing on the master cylinder at all with the pedal all the way up.
