GRU
fear the chicken legs
i think this has been talked about before but im not sure. i am bleeding and bleeding the brakes on the 92 dually and not getting any air. without the truck running the pedal is good and hard. soon as i start the truck up the pedal goes to the floor. pump it up about 3 times and it gets firm for a few seconds then slowly goes to the floor. its not leaking anywhere. previous owner said they had several master cylinders in it but it never cured the problem. the only other thing in the system is whatever "thing" is mounted on the drivers ftramerail that the rear brakeline goes in and comes out of to go to the rear axle. it also has a wire harness on it. what is this thing and could it be the problem? i cant tow my camper to the rally without brakes!! thanks in advance!
foolishness, PLUS that silly load-sensing gizmo that many dualies have.
