tbrumm
Well, guys, I know there is a ton of information on the E4OD on this forum and I did use the advanced search. However, I didn't really see a thread discussing the intermittant shifting problem I am having. It has happened twice now, but only for a short period of time, and both "incidents" have occured about three weeks apart with completely normal operation otherwise. The truck will seem like it is kind of "hunting" for gears and if I step on the throttle it will then shift hard into a gear. If I let off the throttle then it seems like it will try to "hunt' for a gaer again before give it some throttle again. The OD light is not coming on, the factory tach appears to be working fine, the RABS sensor on the rear end was replaced two years ago and seems to be working fine, fluid is at correct level and smells normal. The trans temp gauge is reading right where it always has. The OD button/light is working as I can press the button and get it out of OD. Any thoughts on where to start looking? My suspicion is an electrical issue as the trans has only 80k on oit now, has not been used for towing and has received good maintenance. I appreciate any input you all might have (and yes, I know a ZF5 swap would solve any and all problems I may have but that just isn't on my "to-do" list right now.)
