Odd knock that went away
73idi88f350
michigan
So my truck has had what sounded like a rod knock for the last 2-3weeks and then this whole last week it's gone ***? I'm happy it's not doing it anymore but any suggestions?
occupant
Wichita Falls, TX
Ate a glow plug tip that a took a while to make its way out??
After reading all the FAQs and whatnot this was going to be my first guess. Let's hope the piston doesn't look like this now:
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
I had a sticky injector that knocked so bad I had it towed off the highway. 1 new injector and I was back to making money. It wasn't worth risking an engine to drive any further. The knock was unbelievable. Later an oldtimer showed me how to find a sticky injector knock by feeling the injector line while it was running.
lotzagoodstuff
Carmel, IN
A bad injector will give you a pretty obscene knock, I'd try to figure out about what area it was coming from and then maybe crack the injector lines and see if it gets better or not.
One thing you could do right away at no cost would be to pull all of your glow plugs and inspect them.
73idi88f350
michigan
I just did hg's less then 2 months ago so my pistons looked good a the time of doing head gaskets
The knock sounded down low I had brand mew motor craft glow plugs put in...
Also a few weeks ago I filled my fuel filter with Trans fluid ran it for a few mins and let it sit over night which that helped a lot but didn't do anything about the knocking
and i was also told before to shut the truck down and coast in gear and see if it still knocked and it did
the funny thing was the knock would intermittent.. and only heard it around 1300-2200 rpms.. im gonna assume it at a glow plug tip.. but i dont know..
countrydog
southern Iowa
Make sure you don't have anything contacting the frame or front end. I had an exhuast pipe on an old for that would only touch when you were driving and it sounded exactly like a bottom end knock. It took forever to figure it out...That noise didn't start till we hit a giant culvert playing in the mud and broke the frame behind the double shock tower! LOL
Big Bear
