non wastegate banks turbo complete minus filter box
gingrass179
phoenix, az
Hey guys selling a complete minus filter box non wastegated banks turbo setup...comes off a running engine but I would suggest a rebuild before too long its clean right now but is starting to get some shaft play...doesn't contact the housing and no in or out play...all clamps bolts and nuts are there I've already removed everything and used plenty of PB so no broken parts to worry about...does not have the airbox or cdr but does have the timing cover adapter for the CCV ventilation, intake hat and oring, and boot, oil drain, cast y mount, up pipes, oil feed, 90 oil feed line at block, downpipe, egt sensor, but no gauges to go with it, so you will need either a boost gauge right away or brass plug to take place of the boost gauge fitting . It's currently just a rdt. Pics will be up in a few 600 obo plus shipping at 75 call or text with questions 4355311571
gingrass179
phoenix, az
JunkCowboy
