noise help please
bigdrel
lubbock,tx
It shifts and drives fine. It just has that noise when ******* throttle or towing a trailer. If ur cruising it goes away
Exhaust/boost leak sounds more likely.
Do you have a boost gauge?
Usually a lifter or injector would be making noise all the time.
Being it only does it when you're working it, I'd lean towards boost leak.
Have you checked the intake y boots?
94f450sd
somewhere,ma
Sounds like exhaust leak.a bad injector will make knocky noise at idle and cruise,noise will go away when you get on the throttle.unless its a REALLY bad injector.
bigdrel
lubbock,tx
The turbo spools and supplies boost. I figured an exhaust leak would be noisy while idling too and it's not. It's normal diesel runnin at idle.
PlumberPoopyHands
