mr_smith
91 f250 2wd e4od
I suspect it's in limp mode.. It doesn't shift and only does about 35 mph, which is a guess because the Speedo is not working.
It also felt like it was slipping at high rpms..
I did some searching and the best I came up with is that the VSS is shot..
Is there a fuse or a code I should be looking for? Is the VSS on the diff on a 91?
Thanks!
Thanks!
