No reverse!
tbrumm
Richland Center, WI
I know this post isn't about an IDI, but I have found such a wealth of knowledge and experience here on Oilburners, and members are always willing to help out if they can, so that I thought I would throw this out there. My wife's 2003 Explorer with the 4.6L engine threw a transmission code about 5 months ago. The code (forget the code number) was for a torque convertor fault. The trans guy replaced the solenoid pack ($550.00 with labor) and changed filter and put in new trans fluid (RP MaxATF). Trans has been fine up until yesterday when my wife called from work and said she had no reverse. I always love calls like that becuase she thinks I can somehow diagnose the problem over the phone:dunno. Anyway, I told her to "drive it like she stole it" and get it home. All forward gears worked fine and the trans shifted normally on her trip home (about 50 miles). The OD light and CEL have not come on either which would tell me that the trans is not throwing a code. When she got home, I tried reverse and it worked fine:confused:I looked at her like "what are you trying to do to me?" but she swears she had no reverse. She said she put the selector in reverse and there was nothing. This morning when the truck was cold, I had her try reverse and it worked fine. I know these Explorer transmissions weren't very good - is this a sign that the trans is on its way out soon? Truck has about 130,000 miles on it now and trans has been serviced at regular intervals. I appreciate any insight you guys might have into this problem. I would probably consider trading the Explorer off before I would do a trans rebuild on it. Todd
I'm no automatic transmission expert, but it sounds like a valve in the valve body got stuck. I would change your transmission fluid FREQUENTLY in hopes of keeping the gremlins away.
tbrumm
Richland Center, WI
Thanks for your insight, Mel. Maybe I will pull the pan this weekend and see if there is any debris in the bottom.
May as posted be an issue with the replaced solenoid pack. Just cause it was replaced has no bearing on its value. Could be a used part sold as new. One never knows these days. And now how can you tel if its a new or rebuilt or remanufactured part. Changine the fluid and dropping the pan is a great idea. A filter change along with a fluid change wont hurt anything..
tbrumm
Richland Center, WI
Thanks for the responses, Guys!. The solenoid pack was a new unit from Ford and has been working fine, at least up until now. The trans guy showed it to me before he installed it. Now, did he put something else in after that? I doubt it as he has the reputation around here of being a good trans guy. He also showed me the solenoid pack he removed. I checked around before I took the truck to him. He will at least do diagnosis on trans problems and fix problems that don't require a full rebuild . Almost every other shop around that I called told me that the trans needs rebuilt regardless of what the problem might be. I think the truck has about 10000 miles on it since the solenoid pack replacement/fulid/filter change. The wife drove to work and back today (100 miles round trip) and had absolutely no problems.
trackspeeder
Stone crusher.
North Branford. CT
A good shop will always check out the tranny before saying its totally dead. Unless it's obviously dead.
Electrical gremlins like to show up fro time to time. This was one of them. Take a look at the connectors, check for corrosion or leakage.
If it does happen again, shut the engine off. Restart and try again. Good chance it will reset itself.:D
tbrumm
Richland Center, WI
Thanks for the advice, Trackspeeder. No problems with the truck, but I have informed my wife to shut off the truck and restart if it does it again. That is, before she calls me!
tbrumm
Richland Center, WI
Well guys, I have an update to this little problem. The intermittant no reverse problem continued to get worse and happen more often, so I took the truck to the trans guy. He said that it was the classic bad mpls sensor and that this was a common problem with Fords. Truck still had not thrown a code though. Anyway, he changed the sensor and no change in the reverse issue. So, he started digging and removed the valve body. Little bits of bronze were in there and depending on where they took up residence would determine whether or not reverse worked. He told me I could have him clean it up and put it back together and hope it works for a little longer but the problem would eventually come back as some bushing is disintergrating. OR, I could have him do a full rebuild since he had much of the trans apart already anyway just for the diagnosis. I told him to do the rebuild, since the trans probably wasn't going to go that much longer anyway (125,000 mi on the clock now). Of course, with the rebuild he bored and sleaved the servo bores (which is apparently a common wear location in these Explorer Transmissions) and did whatever updates there were. He has the truck done so I will pick it up tonight and find out what bushing disintergrated and what else was wrong in there. It is just disappointing that keeping your vehicles well maintained doesn't always translate into longer life for some components. You guys sure had the problem pegged with the valve body. Thanks again for your input.
tbrumm
Richland Center, WI
Shooda put a zf in it! :)
Oh, don't I wish! Try to find an SUV with a manual trans in it - they just aren't out there. I had a 94 Explorer with a 5 speed (and it was 4 door not a Sport) and that was a rare animal at that time even. Talked to the trans guy a bit tonight when I picked the Explorer up. He said the convertor came apart internally and that is where the shavings in the valve body came from. He said he was amazed the trans was working as good as it was. He tolds me that Ford uses the V6 convertor with the V8's (which is what is in my wife's Explorer) and that is why they come apart sometimes.
So, what TC did the rebuilder put in it? Triple clutch Hi Performance I would hope. They are expensive tho. Hope your wife don't drive like my Daughter, floors it on ever take off, really ******* automatics and TC's.
PlumberPoopyHands
